9 years agoQuestion about True Dual Port RAM
Hello, I'am using True dual port ram one port for write and the other one for read. When i change the content of an address i get the output on the read port delayed by two cycles. ...
9 years agocan you please explain to me what does it mean to register an output or an input ? i searched the net but i can't find an example. I though that all the outputs when we do the assignment are called registered but i don't think this what it means isn't it ?
And before i could understand what did you mean i changed in the code below to get what i want :
library ieee;
use ieee.std_logic_1164.all;
entity merger is
generic
DATA_WIDTH : natural;
ADDR_WIDTH : natural
port
clk : in std_logic;
addr_a : in natural range 0 to 2**ADDR_WIDTH - 1;
addr_b : in natural range 0 to 2**ADDR_WIDTH - 1;
data_a : in std_logic_vector((DATA_WIDTH-1) downto 0);
data_b : in std_logic_vector((DATA_WIDTH-1) downto 0);
we_a : in std_logic :='1';
we_b : in std_logic:='1';
q_a : out std_logic_vector((DATA_WIDTH -1) downto 0);
q_b : out std_logic_vector((DATA_WIDTH -1) downto 0)
end merger;
architecture rtl of merger is
-- Build a 2-D array type for the RAM
subtype word_t is std_logic_vector((DATA_WIDTH-1) downto 0);
type memory_t is array(2**ADDR_WIDTH-1 downto 0) of word_t;
-- Declare the RAM
shared variable ram : memory_t;
begin
-- Port A
process(clk)
begin
if(rising_edge(clk)) then
if(we_a = '1') then
ram(addr_a) := data_a;
q_a <= data_a;
else
q_a<=data_b;
end if;
end if;
end process;
-- Port B
process(clk)
begin
if(we_b = '1') then
ram(addr_b) := data_b;
end if;
q_b <= ram(addr_b);
end if;
end process;
end rtl;
Is it okay i wrote it like this ? i disable the we_a whenever i want to update the content of the address and read directly the new data ( data_b) (using flags from other modules )
