Questasim UVM macros
Any updates on this?
Richard Tan
yes in one module "dut" it was spelled wrong but still compilation results in error of not finding the uvm_pkg .
i have made some changes see below :
//uvm_sim_pk//
`ifndef UVM_SIM_PK
`define UVM_SIM_PK
package uvm_sim_pk;
`include "C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src/tlm1/uvm_tlm_imps.svh"
`include "C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src/uvm_pkg.sv"
`include "uvm_macros.svh"
import uvm_pkg::*;
class my_transaction extends uvm_sequence_item;
`uvm_object_utils(my_transaction)
rand int addr;
rand int data;
rand bit r0w1;
function new (string name = "");
// Without a string name the transaction would be anonymous
super.new(name);
endfunction: new
//top.sv//
`include "uvm_sim_pk.sv"
module top;
import uvm_sim_pk::*;
dut_if dut_if1 ();
dut dut1 ( .i_f(dut_if1) );
// Test classes are better placed in a package, but defining the class here
// avoids the need to introduce set_config_db to connect the virtual interface
// in this very simple example
//dut.sv//
interface dut_if();
`include "uvm_pkg.sv"
import uvm_pkg::*;
int addr;
int data;
bit r0w1;
modport test (output addr, data, r0w1);
modport dut (input addr, data, r0w1);
// do file //
## Questasim do file ##
vlib work
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_tlm_imps.svh
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_pkg.sv
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_sim_pk.sv
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src dut.sv
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src top.sv
But i still this error :
- RichardT_altera1 year ago
Its a UVM guideline to use .sv extensions for compile files and .svh for `include files.
You're trying to compile uvm_tlm_imps.svh directly:vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_tlm_imps.svh
This is incorrect. Remove that line — the uvm_tlm_imps.svh file will be included inside other UVM source files (like uvm_pkg.sv) automatically.
Richard Tan
