Questasim UVM macros
Again, you use the wrong command.
Use:
vlog -sv -work work +incdir+C:/intelFPGA_lite/24.1std/questa_fse/verilog_src/uvm-1.1d/src uvm_sim_pk.sv
Not
vlog -sv -work work +incdir+C:\intelFPGA_lite\24.1std\questa_fse\verilog_src\uvm-1.1d\src uvm_sim_pk.sv
That's likely what mess up the path name.
Richard Tan
still its not working , i am getting error msg that questasim cannot open uvm_macros.svh in read mode.
Although i am running questasim in admin mode .
- RichardT_altera1 year ago
I attached an example that I used.
Add these script into a .do file then run the .do file.vlib work
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src my_transaction.sv- Fpga_Egr_20251 year ago
Here is the questasim compile result :
I then changed the do file script to include my modules i.e dut.sv and top.sv like this :
## Questasim do file ##
vlib work
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src uvm_sim_pk.sv
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src dut.sv
vlog -sv -work work +incdir+C:/intelFPGA/23.1std/questa_fe/verilog_src/uvm-1.1d/src top.svin my dut.sv : ------------------------------
import uvm_sim_pkg::*interface dut_if();
int addr;
int data;
bit r0w1;modport test (output addr, data, r0w1);
modport dut (input addr, data, r0w1);endinterface: dut_if
module dut(dut_if.dut i_f);always @(*)
begin
$display("DUT received r0w1 = %b, addr = %0d, data = %0d at %0t",
i_f.r0w1, i_f.addr, i_f.data, $time);
end
endmodule: dut------------------------------------------------------------------------------------
in my top.sv : ------------------------------------------------------------------
`include "uvm_sim_pk.sv"
module top;import uvm_sim_pk::*;
dut_if dut_if1 ();
dut dut1 ( .i_f(dut_if1) );// Test classes are better placed in a package, but defining the class here
// avoids the need to introduce set_config_db to connect the virtual interface
// in this very simple example
class my_test extends uvm_test;
// my_test gets instantiated by means of the +UVM_TESTNAME command line argument and run_test()
`uvm_component_utils(my_test)
function new(string name, uvm_component parent);
super.new(name,parent);
`uvm_info("", "Called my_test::new", UVM_NONE);
endfunction: new
my_env m_env;
function void build_phase(uvm_phase phase);
super.build_phase(phase);
`uvm_info("", "Called my_test::build_phase", UVM_NONE);
// Always use the factory instead of new
m_env = my_env::type_id::create("m_env", this);
endfunction: build_phase
function void connect_phase(uvm_phase phase);
`uvm_info("", "Called my_test::connect_phase", UVM_NONE);
// Connect virtual interface in driver to actual interface
m_env.m_driver.m_dut_if = dut_if1;
endfunction: connect_phase
task run_phase(uvm_phase phase);
my_sequence seq;
`uvm_info("","Called my_test::run_phase", UVM_NONE);
seq = my_sequence::type_id::create("seq");
assert( seq.randomize() );
seq.start( m_env.m_sequencer );
endtask: run_phasefunction void report_phase(uvm_phase phase);
`uvm_info("", "Called my_test::report_phase", UVM_NONE);
endfunction: report_phaseendclass: my_test
initial
// Calls static uvm_env::run_test to execute all test phases for all envs & top-level components
run_test("my_test"); // Requires +UVM_TESTNAME at run-timeendmodule: top
questasim compile results :
