Questasim INTEl EDITION counter simulation
- 2 years ago
@GOMEZ_IT, I think you were right, this looks like a simulator problem.
I was able to reproduce your original observation, and it appears to be a bug in older versions of Questa, up to the version shipped with Quartus Pro 23.3.
The version of Questa shipped with Quartus Pro 23.4 doesn't appear to exhibit this symptom. Or at least not with this test case. But I don't know if this was a known bug that got fixed, or if the symptom just went away with other changes in Questa. That's something you should confirm with Intel and/or Mentor/Siemens.
For ease of testing, I modified your test case slightly to be able to run in a more minimalist command line mode, with console messages in lieu of waveforms. See attached zip.
Running this test case with all the simulators I currently have available to me I got the following results:
- Questa from Quartus Pro 22.2: bad
- Questa from Quartus Pro 22.4: bad
- Questa from Quartus Pro 23.1: bad
- Questa from Quartus Pro 23.2: bad
- Questa from Quartus Pro 23.3: bad
- Questa from Quartus Pro 23.4: good
- Modelsim DE 2022.4: good
- ghdl 4.0.0-dev: good
See attached log.txt for the above results.
-Roee
I’m glad that your question has been addressed, I now transition this thread to community support. If you have a new question, Please login to https://supporttickets.intel.com/, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
p/s: If any answer from community or Intel support are helpful, please feel free to mark as solution, give Kudos and rate 5/5 survey
- roeekalinsky2 years ago
Contributor
Can you confirm whether or not this was in fact a known bug that was fixed in the Questa version that shipped with Quartus Pro 23.4?
-Roee
