Questasim INTEl EDITION counter simulation
- 2 years ago
@GOMEZ_IT, I think you were right, this looks like a simulator problem.
I was able to reproduce your original observation, and it appears to be a bug in older versions of Questa, up to the version shipped with Quartus Pro 23.3.
The version of Questa shipped with Quartus Pro 23.4 doesn't appear to exhibit this symptom. Or at least not with this test case. But I don't know if this was a known bug that got fixed, or if the symptom just went away with other changes in Questa. That's something you should confirm with Intel and/or Mentor/Siemens.
For ease of testing, I modified your test case slightly to be able to run in a more minimalist command line mode, with console messages in lieu of waveforms. See attached zip.
Running this test case with all the simulators I currently have available to me I got the following results:
- Questa from Quartus Pro 22.2: bad
- Questa from Quartus Pro 22.4: bad
- Questa from Quartus Pro 23.1: bad
- Questa from Quartus Pro 23.2: bad
- Questa from Quartus Pro 23.3: bad
- Questa from Quartus Pro 23.4: good
- Modelsim DE 2022.4: good
- ghdl 4.0.0-dev: good
See attached log.txt for the above results.
-Roee
Looks like I was mistaken. An initial value at the variable declaration in the process takes effect at time zero, not at every entry into the process. Learn something every day.
But now, the mystery deepens. This explains why it does work, but it doesn't explain why your original example didn't work. And in fact, simulating it both ways on my end, I see it work in both cases. I can't reproduce your original result of it not working.
You didn't share your test bench, so I created a simple one to simulate it on my end. I'm curious if the crux lies in how you're generating the inputs to this module, if there is some gotcha there somehow. Can you please share your test bench code?
This is the bench code:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use IEEE.STD_LOGIC_ARITH.ALL;
use IEEE.STD_LOGIC_UNSIGNED.ALL;
entity COUNT8_tb is
end COUNT8_tb;
architecture Behavioral of COUNT8_tb is
signal CLK : std_logic := '0';
signal EN : std_logic := '0';
signal DOUT : std_logic_vector(7 downto 0);
begin
-- Clock process
process
begin
wait for 5 ns;
CLK <= not CLK;
end process;
-- Stimulus process
process
begin
wait for 10 ns;
EN <= '1';
wait;
end process;
-- Instantiate the COUNT8 module
uut :entity work.COUNT8
port map (
CLK => CLK,
EN => EN,
DOUT => DOUT
end Behavioral;
