Fpga_Egr_2025
1 year agoQuestasim FSE license setup
Hi, I generated a fixed node license for Questa*-Intel® FPGA Starter Edition SW-QUESTA to enable my Questasim FSE (Quartus Prime 24.1) from intel self service license portal . The .dat lic...
- 1 year ago
You may delete the MGLS_LICENSE_FILE environment variable or update its value to point to your correct license path.
It looks like Questa is currently using MGLS_LICENSE_FILE, but the path specified is invalid or does not exist (as you stated).
This is likely the root cause of the issue.
The MGLS_LICENSE_FILE takes precedence over LM_LICENSE_FILE settings.
Richard Tan
Fpga_Egr_2025
1 year agoThanks RichardTanSY_Intel , your solution worked
