Questasim FSE license setup
- 1 year ago
You may delete the MGLS_LICENSE_FILE environment variable or update its value to point to your correct license path.
It looks like Questa is currently using MGLS_LICENSE_FILE, but the path specified is invalid or does not exist (as you stated).
This is likely the root cause of the issue.
The MGLS_LICENSE_FILE takes precedence over LM_LICENSE_FILE settings.
Richard Tan
I created a simple schematic in Quartus and have the same problem when I try to run a simulation using Questa.
See attachments for license configuration. I found a few posts on this, but no solutions that worked for me.
HELP!
I ran lmutil (before I renamed file to license.dat):
C:\licenses\flexlm>lmutil lmdiag -c LR-232439_License.dat
lmutil - Copyright (c) 1989-2022 Flexera. All Rights Reserved.
FlexNet diagnostics on Sat 5/3/2025 16:15
License file: LR-232439_License.dat
"quartus_nonvolatile_encryption" v2026.05, vendor: alterad, expiry: permanent(no expiration date)
uncounted nodelocked license, locked to ethernet address "c07cd1ff4ad1" no expiration date
TS_OK: Checkout permitted when client is using terminal client
This is the correct node for this node-locked license
