sselhorst's avatar
sselhorst
1 day ago
Questa warning vsim-3473 Component instance is not bound.
I am using Quartus Prime Pro 25.3 and Questa Altera Starter FPGA Edition-64 2025.2. I am trying to simulate a design with numerous Altera IP. I get the "not bound" warning for the many, possibly all, of the Altera IP. I have searched online and this forum. I see the same problem identified with ModelSim. I could not find anything specifically Questa. I have tried various posted solutions but have had no success. I generated simulation models for all IP in Quartus. For one of the IP, I tried creating the simulation model in VHDL and Verilog and tried Traditional and Qrun QuestSim flow selection. I checked the QuestaSim box for which simulator script will be generated. I found some solutions talking about using the command line in Questa. I very much prefer to remain in in the GUI for all commands.
1 Reply
  • Hi sselhorst
    Have you tried the automating simulation with the run simulation feature?
    The official user guide is available here:
    https://docs.altera.com/r/docs/730191/25.3/questa-edition-simulation-user-guide/automating-simulation-with-the-run-simulation-feature
    This flow will automatically:
    -Generate the required simulation setup files
    -Compile the Altera IP simulation models
    -Compile the design files
    -Launch Questa
    If the issue still persists, could you please share the design .qar file (Project → Archive Project) so that we can investigate further?
    Richard Tan
