Questa Starter Edition Bad License File Generated
- 4 years ago
I generated licenses until I got a working one. Most of them ended up just containing comments, but I ended up with license which actually worked after trying for a while.
Hi, have you managed to find a workaround to this issue? I tried to generate different licenses, but still get a fatal error message. Both direct license selection and environment variable set fail too.
- arnef4 years ago
- BalenMars4 years ago
Are you saying this is just a block of comments that have been generated?
# Intel Corporation Software and/or Intellectual Property License File
# Issued 12 April 2022
# Upgrade to these products will no longer be available after the Maintenance Expiration
# date unless licenses are renewed.
# Fixed Node License
# Primary Machine Name-Balen-PC
# Primary Machine ID-NIC ID ************
# Companion ID-NIC ID ************
# Companion ID 2-N/A
# Product License Summary:
# Questasim*-Intel® FPGA Starter Edition, 1 Seat(s)
# - Maintenance Expiration of 2023.04
# - License Expires 12-Apr-2023
# FEATURE START
# This is license file for Questasim*-Intel® FPGA Starter Edition
# Number of seat licenses is 1
# License Expires 12-Apr-2023
# FEATURE END
# End of Intel Corporation Software and/or Intellectual Property License File. Issued 04/12/2022 - BalenMars4 years ago
OK, I finally generated a working license! It's either they fixed the bug or the it's still there corrupting the license generation every now and then.
- arnef4 years ago
I have no idea, but you can clearly see the difference in what is supposed to be the license code and what is just comments. Nice to hear you worked it out!
