haris
3 months agoQuesta-ModelSim UI scaling problems in Linux
Hello Has anybody been able to solve the issue of UI of Questa not scaling correctly on linux with wayland? I am using Ubuntu 26.04 with wayland and UI is just tiny, icons, are so small i cannot ...
fmasmits
30 days agoHello ZiYingE_Altera,
It appears on all screens.
Even if I reduce the resolution through OS settings, it changes nothing.
cheers,
Finn
ZiYingE_Altera
Contributor
30 days agoHi fmasmits,
Just to provide some additional clarification, Ubuntu 26.04 is not yet officially supported by Questa Altera FPGA Edition.
As a result, unexpected behavior or issues may occur since this operating system has not yet been fully validated. You may refer to the supported operating systems here: https://www.altera.com/design/guidance/software/os-support
In the meantime, I will see if I can obtain access to another supported Ubuntu version on my end to help reproduce and investigate the issue further.
Thank you.
ZiYingE_Altera
