haris
3 months agoQuesta-ModelSim UI scaling problems in Linux
Hello Has anybody been able to solve the issue of UI of Questa not scaling correctly on linux with wayland? I am using Ubuntu 26.04 with wayland and UI is just tiny, icons, are so small i cannot ...
ZiYingE_Altera
Contributor
1 month agoHi fmasmits,
Thank you for the update and for trying the suggested steps.
May I know the resolution of your monitor?
Thank you.
ZiYingE_Altera
ZiYingE_Altera
Contributor
Just to add to my previous question, besides the monitor resolution, could you also share the desktop environment you are using?
You may run with the following command in the ubuntu terminal:
echo $XDG_CURRENT_DESKTOP
echo $XDG_SESSION_TYPE.
This will help us better understand the display environment on your system.
Thank you.
ZiYingE_Altera
