ELIT1
1 year agoQuesta Intel FPGA Edition crash.
Hi. When trying to open any previously perfectly working project - simulator crashes. Attached stack trace. Simulator Version 2024.1 (Quartus Prime Pro 2024.3). Windows 10 Pro 22H2. Please help...
- 1 year ago
Hi Richard.
I reinstalled Windows and everything worked as expected.
So suddenly a Windows problem arose, which, unfortunately, could not be fixed by Microsoft tools - DISM and System File Checker.
The only solution is to reinstall Windows.
Thank you very much for your support.
ELIT1.
RichardT_altera
1 year agoThis error message indicates an access violation (exception code C0000005), which occurs when a program attempts to read or write to an invalid memory location.
Could you try running it on a different machine to see if the issue persists?
If it works, that would provide a good comparison between the two machines.
Alternatively, you may try moving the project directory to a folder where you have the access permissions.
Richard Tan
