Questa Intel FPGA Edition crash.
- 1 year ago
Hi Richard.
I reinstalled Windows and everything worked as expected.
So suddenly a Windows problem arose, which, unfortunately, could not be fixed by Microsoft tools - DISM and System File Checker.
The only solution is to reinstall Windows.
Thank you very much for your support.
ELIT1.
May I know how do you install the software ?
Could you try to uninstall the Questa software and reinstall again ?
Before you install,
1. Check that the disk space is sufficient for the installation of the Intel FPGA software.
2. If you are running antivirus software, try to temporarily disable the antivirus software during the Questa software download and installation process.
3 Install the software with Administrator privileges.
4. Try to download and auto install using the new Quartus installer.
Richard Tan
Hi Richard,
I installed the Quartus Prime Pro 24.3, including Questa Intel Edition, on 11/12/2024.
The simulator worked without any problem until 06/02/2025.
When suddenly on 06/02/2025 the simulator started to crash,
I reinstalled it, but unfortunately it didn't help.
To continue urgent work, I had to reinstall ModelSim IE 21.2, which works without any problems.
I always install any software with Administrator privileges.
There was never a case where Norton Antivirus interfered with the installation of any program,
including Quartus & Questa 11/12/1924, so I never temporarily disabled it.
Eliyahu Trigoub.
