Questa Intel FPGA Edition crash.
- 1 year ago
Hi Richard.
I reinstalled Windows and everything worked as expected.
So suddenly a Windows problem arose, which, unfortunately, could not be fixed by Microsoft tools - DISM and System File Checker.
The only solution is to reinstall Windows.
Thank you very much for your support.
ELIT1.
May I know how you simulate your design?
We simulate the design using a simulation script. Refer to the user guide below and try simulating using the recommended flow.
You may also choose to simulate using the example design provided in the user guide.
https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/quick-start.html
Does the tool works before? If so, check your OS history update, e.g. to check if the issue happen after some specific Window update.
Richard Tan
