djmohab2
2 years agoQuesta install not working
I have downloaded the install archive several times, un-installed, and re-installed Questa, and when I start the program, it gives me a command shell and exits out. Here is the install log. I need as...
ShengN_altera
2 years agoHi,
Do you have any further concern or consideration?
Sheng
djmohab2
2 years agoYes, I have concerns as your advice has not actually done anything to help address them. I am running Windows 11, which as far as I know is a compatible OS. What individual file are you talking about? I downloaded QuestaSetup_23.4.0.79-windows directly from your portal.
The fact that you tested without any issues is irrelevant because that information does not fix or give any help to solving my issue at all.
