Questa FSE can not check out a license even after LM_LICENSE_FILE is set up correctly
- 1 year ago
OK, for those that were still searching or looking for an answer, I guess I just solved this on my own as I never got a reply in a timely manner, so the ANSWER is Yes, I attached the license file text above, while the Altera licensing manger only generated one license.dat file, the text inside the actual file has two instances of some kind of license, SO I commented out the first set of data above, (I guess just putting a hash mark # is the comment character) and if I did this then when I start Questa, it does indeed start without error, now I have to go back and add all the other licenses back into my windows environment variable, as I tore all that out to aid in debugging,
and this is of no help either as downloading and installing an updated siemens license manger gives a similar result
