Questa .exe not being seen
- 2 years ago
Need to specify the simulator LM_LICENSE_FILE path check this document link https://www.intel.com/content/www/us/en/docs/programmable/683472/23-3/faq.html (page 47):
On Windows System
1. Go to This PC, right-click, and select Properties.
2. Click Advanced System Setting.
3. In the Advanced tab, select Environment Variable.
4. Under System variables, create a new variable with the name asLM_LICENSE_FILE and value as <license.dat file path>.
5. Click OK and restart the Questa*-Intel FPGA Edition software.
Alternatively, open a command prompt and run the following command to set up the LM_LICENSE_FILE environment variable:
setx LM_LICENSE_FILE <path_to_license_file>;%LM_LICENSE_FILE%
For example: setx LM_LICENSE_FILE C:\intelFPGA \license.dat;%LM_LICENSE_FILE%
Sheng
I tried that and it did not work. Quartus cannot see Questa.
Thank you for trying, hopefully this can be resolved soon.
Drew
