Questa does not run on Redhat 8.7 in a virtual machine
I am mostly there and the last issue is minor... I still can't invoke Questa from Quartus and it seems to be a missing file. I tried reinstalling everything, but still not working. Here is the error from the Nativelink log.
Info: Using NativeLink to launch synthesis Tool
Synthesis tool <None> is not supported by NativeLink
Error: NativeLink flow failed to complete synthesis
================The following information is provided to Debug NativeLink Script=================
Nativelink TCL script failed with errorCode: POSIX ENOENT {no such file or directory}
Nativelink TCL script failed with errorInfo: couldn't open "/home/eeleigh/altera/24.1std/quartus/linux64/tclIndex": no such file or directory
while executing
"open [file join $dir tclIndex]"
PATH Environment Variable is set to : /home/eeleigh/altera/24.1std/quartus/adm:/home/eeleigh/altera/24.1std/quartus/linux64:/home/eeleigh/.local/bin:/home/eeleigh/bin:/usr/local/bin:/usr/local/sbin:/usr/bin:/usr/sbin
