UmarM
2 years agoQuesta Compile error vcom-212 Stack hard limit
Hi We have installed Intel Quartus 23.4 with all of dependencies and modules on RHEL 8.7. When we run Questa and try to compile a model we are getting an error message stating Error (suppressible)...
UmarM
2 years agoHello Syafieq,
I am sorry, I did not understand your last message, I don't know from where you got this impression that we can't see it. What I replied in my last message was that we tried your solution of setting environment variable by using the command you sent which was;
running the following command before starting Questa e.g.:
export VCOM_STACK_SIZE=134217728
Once again, we ran this command, and ran the Questa and tried compiling a model, but still were getting the same error.
