UmarM
2 years agoQuesta Compile error vcom-212 Stack hard limit
Hi We have installed Intel Quartus 23.4 with all of dependencies and modules on RHEL 8.7. When we run Questa and try to compile a model we are getting an error message stating Error (suppressible)...
SyafieqS
2 years agoYou can try increasing the stack hard limit for the vcom compiler. You can do this by setting the VCOM_STACK_SIZE environment variable to a higher value. For example, you can set it to 134217728 (128 MB) by running the following command before starting Questa e.g.:
export VCOM_STACK_SIZE=134217728
After setting the environment variable, try compiling your model again.
Let me know.
