Tom_Gambill
1 year agoQuesta 24.3 Splash Screen, then nothing, no error or crash, just exits
This is happening on two separate machines both with Windows 11, exact same behavior...Launch the app from the Questa FSE icon it installed on the desktop, it displays a QuestaSIM splash screen for a...
- 1 year ago
OK, it turns out it is the license file path. The scary dialog during installation says that you should no longer use the LM_LICENSE_FILE key, but instead set a SALT_LICENSE_FILE key. However, just setting that other key will make the license manager happy, and prevent Questa from reporting no license, but causes it to just exit after the splash screen...
I added both keys pointing to the same license file and it works now on both machines...Not sure if the SALT one is even needed, but I seem to be good now. That was very misleading...
sstrell
1 year agoIs your LM_LICENSE_FILE environment variable pointing at the license file?
