Anpeng
1 year agoQUESTA 2024.1 simulation error
Hi, all ! I encountered an error while using QUESTA 2024.1 for IP simulation, and I would like to know where the issue lies. Below are the steps I took: 1. generate simulator script set up for ip ...
- 1 year ago
I believe there is a missing steps in your design. Can you follow the steps in https://www.intel.com/content/www/us/en/docs/programmable/691278/21-3/prerequisites.html and let me know if does not work?
I have tested this example design and it works.
KennyT_altera
1 year agoIs there any update?
- Anpeng1 year ago
I have solved the problem, thank you very much!
