PravinKumar
1 year agoQuery in the Post Route results.
May I know how implemented frequency is calculated here and why the FMax is calculated in that way. I am seeing the difference in calculating Fmax for the design. Highlighted the considered values ...
ShengN_altera
1 year agoHi,
FvM is right. You may check this document link https://cdrdv2-public.intel.com/666844/a10_datasheet-683771-666844.pdf (page 36):
| Parameter | Performance (All Speed Grades) | Unit |
| Global clock, regional clock, and small periphery clock | 644 | MHz |
| Large periphery clock | 525 | MHz |
As for setup slack, you may go to Assignments -> Settings -> Compiler Settings -> choose Performance
Sheng
