PravinKumar
1 year agoQuery in the Post Route results.
May I know how implemented frequency is calculated here and why the FMax is calculated in that way. I am seeing the difference in calculating Fmax for the design. Highlighted the considered values ...
FvM
1 year agoHi,
your design fails timing analysis because Arria 10 maximum core clock frequency of 644 MHz is exceeded (timing analyser uses rounded value of 645.16MHz = 1/1.55ns). This causes a "minimum pulsewidth" violation for clk and a respective restricted Fmax value.
Possible contradicting reported values in timing analysis are referred. You need to solve the minimum pulsewidth problem first.
Frank
