10 years agoQuatus TCL Integration with Assignments
So I'm trying to build a date/time register that is updated every build. I was going to use a TCL script to generate a global assignment, and then use that global_assignment in my VHDL code as a register value.
The question is: is this even possible? I understand how to get scripts to run (https://www.altera.com/support/support-resources/design-examples/design-software/tcl/auto_processing.html), but how can I pull assignments in to my HDL? EDIT: Sorry about the bad thread title. Hopefully an admin can come around and fix it.3 Replies
No, you cannot access global_assignments from VHDL.
However, you can have TCL spit out some VHDL (a package for example) with some constants in it that set the values of some registers. - Altera_Forum
--- Quote Start --- No, you cannot access global_assignments from VHDL. However, you can have TCL spit out some VHDL (a package for example) with some constants in it that set the values of some registers. --- Quote End --- That's a great idea. I'll instantiate a block is generated by a TCL script to spit out a constant. That's an acceptable workaround. I'm surprised there isn't a megafunction for "build time". - Altera_Forum
--- Quote Start --- That's a great idea. I'll instantiate a block is generated by a TCL script to spit out a constant. That's an acceptable workaround. I'm surprised there isn't a megafunction for "build time". --- Quote End --- Works great. Automatic VHDL generation. Easy enough to add Verilog. If anyone is interested in the files, just let me know.
