For installing only Cyclone II support, I have successfully tested installations on several different Windows computers by my batch file, see below.
Usage:
- To unpack files, run the first steps of installations of Quartus II web, ModelSim SE, and Nios.
- Edit SETs of directories in beginning batch file, if you unpacked files in different directories.
- Fill your proxy address. I did not actually test, if a proxy setting is required, may be not.
- Add other devices, if you need. I created batch for installing only cycloneii.qda.
- Store corrected bat file for example as SETUP.BAT into root directory of a drive. (I have created the DVD image file *.iso by NERO that I open as a virtual drive for installations).
Richard
----------------- Batch file for windows----------------
IF "%1" == "" GOTO NO-PARAMS Prompts if No Parameter was Specified
IF "%2" == "" GOTO NO-PARAMS Prompts if No Parameter was Specified
SETLOCAL
SET quartus_source_drive=%1
SET quartus_dest_drive=%2
SET quartus_source=%quartus_source_drive%:\10.0_quartus_free_windows
SET quartus_sourcems=%quartus_source_drive%:\10.0_modelsim_ase_windows
SET quartus_sourceni=%quartus_source_drive%:\10.0_nios2eds_windows
SET quartus_target=%quartus_dest_drive%:\altera\10.0
SET temp_dir=
C:\Temp SET proxy=your.proxy.server:port
cd %quartus_source%
"altera_installer\bin\altera_installer_cmd.exe" --install=quartus_free --web --source="%quartus_source%" --target="%quartus_target%" --temp="%temp_dir%" --proxy=%proxy% --no_space_check
cd %quartus_source%\devices\subscription
"%quartus_target%\quartus\bin\quartus_sh.exe" --qinstall -qda cycloneii.qda -show_qt_progress
cd %quartus_sourcems%
"altera_installer\bin\altera_installer_cmd.exe" --install=modelsim_ase --source="%quartus_sourcems%" --target="%quartus_target%" --temp="%temp_dir%" --proxy=%proxy% --no_space_check
cd %quartus_sourceni%
"altera_installer\bin\altera_installer_cmd.exe" --install=nios2eds --source="%quartus_sourceni%" --target="%quartus_target%" --temp="%temp_dir%" --proxy=%proxy% --no_space_check
ENDLOCAL
@echo ********************** Done *************************
@GOTO END
:NO-PARAMS
@ECHO ====================================================
@ECHO The installation of
@ECHO 1) Quartus II 10.0 Web Edition,
@ECHO 2) ModelSim-Altera Start Edition
@ECHO 3) Nios II Embedded Design Suite
@ECHO into destination directory DestDriveLette
r:\altera\10.0 @ECHO .
@ECHO Usage: setup.bat SourceDriveLetter DestDriveLetter
@ECHO Example: setup.bat D C
:END
@pause
