15 years ago --- Quote Start --- Altera recently published a command line solution in their knowledge base. I think this should be the command line workaround provided by them. Susta, i think the command line examples will install the device families as well. I notice that they use "all" option which i assume a full install. --- Quote End --- Hmm. I am having a similar problem getting a part install to work. There is no AVG involved. I shall try the command line option and see if it works. TNX Pete
