aakkü
6 years agoQuartus won't let me use Signal Tap. Can't elaborate "sld_hub:auto_hub"
Hello, I've been dealing debugging issues for quite a while with my FPGA design. I had to use Signal Tap for advanced debugging, but for some reason it can't be used. I am just following the tut...
aakkü
6 years agoIt works with no problems on ubuntu even in virtual machine.
The problem has obviously something to do with OS.
I think language packages has something to do with this. I'll keep you informed when I install windows 10 with no language packages. Right now I'm using Turkish version of Windows 10, next time when I reinstall windows I try to install US version.
If it fixes anything I let you know.
For now I keep using linux.
