aakkü
6 years agoQuartus won't let me use Signal Tap. Can't elaborate "sld_hub:auto_hub"
Hello, I've been dealing debugging issues for quite a while with my FPGA design. I had to use Signal Tap for advanced debugging, but for some reason it can't be used. I am just following the tut...
SyafieqS
6 years agoHi Alrepen,
I tried to compile the design using latest version 19.1 Lite and cannot reproduce the error. Even with and without stp and did it several times. I suspect this error might be related to Quartus SW itself at your side could be due to installation issue etc. Did you have multiple Quartus installed in your machine? Not recommended to do so. Also make sure your OS compatible and up to date. I will try to run it in Linux if it is OS issue.
- aakkü6 years ago
Yes I did try multiple versions on different computers. Single version of quartus is installed at any given time.
I am using windows 10 right now and I consistently get the same error.
Tried to reinstall many times, no luck...
