aakkü
6 years agoQuartus won't let me use Signal Tap. Can't elaborate "sld_hub:auto_hub"
Hello, I've been dealing debugging issues for quite a while with my FPGA design. I had to use Signal Tap for advanced debugging, but for some reason it can't be used. I am just following the tut...
sstrell
6 years agoUnfortunately, I'm not getting this error either when I compile your design.
What are the messages that appear just before the error you posted, especially the warnings that are mentioned above? They can help clue into where in your design is the issue.
Have you tried compiling with Signal Tap disabled? Is that successful?
#iwork4intel
