Shihang
2 years agoQuartus synthesis internal error
When I synthesized a project I'm working on, Quartus encountered an internal error (log copied below).
This error only occurred after I re-cloned the repository under a different directory. Quartus was able to compile an identical project under its original directory.
Thanks in advance. Help is much appreciated.
Problem Details Error: Internal Error: Sub-system: SCL, File: /quartus/synth/scl/scl_wysiwyg_atom_factory.cpp, Line: 2763 ::scl_alloc_wys_atom_for_nadder(): Cannot read hex file: /mnt/sda1/projs/cxl_tm2/intel_rtile_cxl_top_0_ed/hardware_test_design/common/mc_top/emif_ip/emif_cal_two_ch/altera_emif_cal_iossm_274/synth/emif_cal_two_ch_altera_emif_cal_iossm_274_psjm22a_code.hex Stack Trace: Quartus 0x7b993: scl_alloc_wys_atom_for_falconmesa(CDB_SGATE_WYSIWYG*, CGA_INTERFACE*, ATOM_NETLIST_NODE_ADDER&) + 0x1307 (synth_scl) Quartus 0x7e90a: SCL_WYSIWYG_ATOM_FACTORY_IMPL::alloc_wys_atom(CDB_SGATE_WYSIWYG*, CDB_ATOM_NETLIST&) + 0x18ca (synth_scl) Quartus 0x338e9: FTM_ATOM_BUILDER::map_wys_sgate(CDB_SGATE_WYSIWYG*) + 0x39 (synth_atm_build) Quartus 0x7785b: FTM_GENERIC_ATOM_BUILDER::build_atom_network_v() + 0x57b (synth_atm_build) Quartus 0x2fd02: FTM_ATOM_BUILDER::build_atom_network(CDB_SGATE_NETLIST*, SCL_WYSIWYG_ATOM_FACTORY*) + 0x12 (synth_atm_build) Quartus 0x8f22c: FTM_ROOT_IMPL::build_atoms() + 0x42c (synth_ftm) Quartus 0x8f6d2: FTM_ROOT_IMPL::start_atom_builder() + 0x52 (synth_ftm) Quartus 0x8f8df: FTM_ROOT::start_atom_builder(CDB_SGATE_NETLIST*, SCL_WYSIWYG_ATOM_FACTORY*) + 0x8f (synth_ftm) Quartus 0x8af16: SCL_SYN_HIER::do_atom_build(CDB_SGATE_NETLIST*) + 0x16c (synth_scl) Quartus 0x36aef: scl_run_ftm_atom_build(CMP_FACADE*, SAM_FACADE*, CDB_SGATE_HIERARCHY*, CDB_SGATE_NETLIST*) + 0x72 (synth_scl) Quartus 0x2d267e: SYNTH::QIS::SYNTHESIS_FLOW::ftm_atom_building_cdb() + 0x42 (synth_qis) Quartus 0x2d3847: SYNTH::QIS::SYNTHESIS_FLOW::ftm_atom_building() + 0x1f (synth_qis) Quartus 0x2e0822: SYNTH::QIS::SYNTHESIS_FLOW::run_current_phase() + 0x332 (synth_qis) Quartus 0x2e0e94: SYNTH::QIS::SYNTHESIS_FLOW::run_full_flow(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, bool, bool, QIS_RTL_STAGE::FLOW) + 0x468 (synth_qis) Quartus 0x1ac604: QIS_RTL_STAGE::IMPL::synthesize(QHD_PARTITION&, bool, bool, QIS_RTL_STAGE::FLOW) + 0x508 (synth_qis) Quartus 0x1ac914: QIS_RTL_STAGE::synthesize(QHD_PARTITION&, bool, bool, QIS_RTL_STAGE::FLOW) + 0x12 (synth_qis) Quartus 0xc8a59: qis_synthesize + 0x302 (synth_qis) Quartus 0x4bb47: TclNRRunCallbacks + 0x67 (tcl8.6) Quartus 0x4cf29: TclEvalEx + 0x599 (tcl8.6) Quartus 0xf40fe: Tcl_FSEvalFileEx + 0x21e (tcl8.6) Quartus 0xf4246: Tcl_EvalFile + 0x26 (tcl8.6) Quartus 0x2708e: qexe_evaluate_tcl_script(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x388 (comp_qexe) Quartus 0x29dec: qexe_do_tcl(QEXE_FRAMEWORK*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > > const&, bool, bool) + 0x71b (comp_qexe) Quartus 0x2afa5: qexe_run_tcl_option(QEXE_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x8a5 (comp_qexe) Quartus 0x77f9d: QCU::DETAIL::intialise_qhd_and_run_qexe(QCU_FRAMEWORK&, FIO_PATH const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x99 (comp_qcu) Quartus 0x78290: qcu_run_tcl_option(QCU_FRAMEWORK*, char const*, std::__cxx11::list<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >, std::allocator<std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > > >*, bool) + 0x286 (comp_qcu) Quartus 0x40730e: qsyn2_tcl_process_default_flow_option(ACF_VARIABLE_TYPE_ENUM, char const*) + 0x4b5 (quartus_syn) Quartus 0x2fb9a: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x7dd (comp_qexe) Quartus 0x406d4c: qsyn2_main(int, char const**) + 0x123 (quartus_syn) Quartus 0x43f80: msg_main_thread(void*) + 0x10 (ccl_msg) Quartus 0x44a00: msg_thread_wrapper(void* (*)(void*), void*) + 0x8c (ccl_msg) Quartus 0x1fcfd: mem_thread_wrapper(void* (*)(void*), void*) + 0x9d (ccl_mem) Quartus 0xe168: err_thread_wrapper(void* (*)(void*), void*) + 0x1e (ccl_err) Quartus 0x44929: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0xd3 (ccl_msg) Quartus 0x406c22: main + 0x26 (quartus_syn) System 0x29d90: (c) System 0x29e40: __libc_start_main + 0x80 (c) Quartus 0x406b49: _start + 0x29 (quartus_syn) End-trace Executable: quartus Comment: None System Information Platform: linux64 OS name: Ubuntu OS version: 22 Quartus Prime Information Address bits: 64 Version: 24.1.0 Build: 115 Edition: Pro Edition
- Quartus is missing a file that is expected to be produced during IP HDL generation. This usually happens when your repository contains some generated files but not all so that not all IP is automatically regenerated during first compile of a clean checkout.
Try to select regeneration of all IP files in library settings.
1 Reply
- FvM
