Quartus synthesis deletes bits of a variable that gets a constant value
- 5 years ago
The input patterns requested all match to 4 possible cases – the MSB exactly, the LSB exactly, Or values E or 8
This seems to match exactly to the design being inferred by synthesis – what is being compared is ambiguous in the netlist viewer diagram, but it is using the MSB, LSB and these two 4-bit constants to accomplish the comparison.
Since every individual bit takes resources in an FPGA, it makes sense to minimize the functions like this to save resources.
It can be seen in Signal Tap tool:
You can see here that compare_data0 has only 2 bits, and compare_data1 is not even there.
And also in scheme it can be seen that the constant that goes to comparison is incorrect:
In the lab on the FPGA itself it does not compare it correctly. I get 0x800 or 0xC00 for the constants which means only the two MSBs are changing.
I am adding here again the code:
module HT3Input12 (
input selector_msb,
input selector_lsb,
input [11:0] InData0,
input [11:0] InData1,
output check
wire [11:0] Data0 = InData0;
wire [11:0] Data1 = InData1;
reg [11:0] Compare_data0;
reg [11:0] Compare_data1;
// Selectors MAP
// 00 - Send 0s on all pins
// 01 - Send a series of '101010...' , first bit is '1'
// 10 - Send a series of '010101...' , first bit is '0'
// 11 - Send 1s on all pins
always @(*)
case ({selector_msb,selector_lsb})
2'b00:
begin
Compare_data0 = 12'd0;
Compare_data1 = 12'd0;
end
2'b01:
begin
Compare_data0 = 12'hABC;
Compare_data1 = 12'h789;
end
2'b10:
begin
Compare_data0 = 12'b101010101010;
Compare_data1 = 12'b101010101010;
end
2'b11:
begin
Compare_data0 = 12'hFFF;
Compare_data1 =12'hFFF;
end
endcase
assign check = ((Data0 == Compare_data0) && (Data1 == Compare_data1)) ? 1'b1 : 1'b0 ;
endmodule
Do you know how can I report a bug on Quartos?
