Quartus Simulation Waveform Editor
I am able to highlight the waveform though, using Quartus Standard 23.1 in Window 11 OS.
Which Quartus version and OS system that you are using?
There are a few things that you can troubleshoot:
1. Try restarting Quartus and your computer. This can help clear any temporary issues that may be causing the error.
2. Before you download and install the software, please check that your machine system must meet minimum Hardware and Software Requirements. Ensure that your Operating System is supported. https://www.intel.com/content/www/us/en/docs/programmable/683472/current/system-requirements-and-prerequisite.html
3. If you are running antivirus software, try to temporarily disable the antivirus software during the Quartus Prime software download and installation process.
4. Install the software with Administrator privileges.
5. If install using .tar, try to re-download the Quartus .tar installation package and install again. Check that the installation files .tar is not corrupted by checking the checksum.
6. Alternatively, try to download and auto install using the new Quartus installer.
7. Check your OS history update, e.g. to check if the issue happen after some specific Window update.
Richard Tan
