JDeForest
6 years agoQuartus_sh terminated with unexpected exit code 1. Help?
Hi All, I keep getting the following error: Error(293007): Current module quartus_sh terminated with unexpected exit code 1. This may be because some system resource has been exhausted. You can vi...
JDeForest
6 years agoHello,
Unfortunately no, I am still stuck on this error.
I have gone through the compilation flow to try to compile things individually.
The only one that will finish is "IP Generation". The rest all seem to force "Analysis & Synthesis" to run, which is where I keep getting errors. I am currently trying to fix these errors.
One thing I don't really understand why it gives me errors with the code when I run it individually, but it gives me a resources error when I run it as a whole.
Thank you,
Joshua
