Quartus_sh terminated with unexpected exit code 1. Help?
1. Quartus Prime type and version: Quartus Prime Version 19.4.0 Build 65 12/04/2019 SC Pro Edition
2. Type of OS you used: Windows 10 Version 1909 (OS Build 18363.720)
3. Your machine specification ( drive, ram , etc.) : Intel Core I7-4771, RAM: 16GB Virtual and 16GB Physical, Drives: Kingston 240GB SSD and Western Digital 1TB HDD, GPU: NVIDIA Quadro K4200.
If I missed anything, please let me know.
The only licensed IP that I believe I am using is Hard IP for PCI Express. I will read through that link you sent and try to verify that. Is there a piece of the compilation that I can run (like possible IP Generation) that would allow me to verify that that is not a licensing issue?
I will call every background process that I can that is not needed and try to compile again.
Thank you,
Joshua.
