10 years agoQuartus RTL Viewer crashes
I'm using Quartus II v13.1 for an existing project and wanted to check my design with RTL viewer after I made some modifications.
Unfortunately, Quartus II systematically crashes with the following error message. Any advice? thanks Jylo *** Fatal Error: Int Divide By Zero Module: quartus.exe Stack Trace: 0x103e54: QPainterPath::ensureData + 0x394 0x104150: QPainterPath::ensureData + 0x690 0x103765: operator* + 0x285 0x165f: safer_scalable_free_msvcr100 + 0xf 0x18c162: QPaintDevice::depth + 0xe1e2 End-trace Quartus II 32-bit Version 13.1.0 Build 162 10/23/2013 SJ Web Edition4 Replies
You'll have to raise a ticket with altera my support. But is there any reason you're not using a newer version? Q13 is v unlikely to get a fix
--- Quote Start --- But is there any reason you're not using a newer version? Q13 is v unlikely to get a fix --- Quote End --- Just because Altera usually recommended not to upgrade while in the middle of a development process. This project has been started couples years ago but is still under development. Our intend is to switch to a newer version to be able to use newer devices (such as Max10), but we first need to complete this project based on Cyclone IV. Thanks anyway for your feedback. - Altera_Forum
If you're a big enough customer (ie, you buy enough chips) and the problem is going to block of lot of chip sales, you may get a special Quartus Build. But other than that, you're going to have to contact them
They may be able to tell you what the problem is anyway, and give you a work around.. - Altera_Forum
--- Quote Start --- If you're a big enough customer (ie, you buy enough chips) and the problem is going to block of lot of chip sales, you may get a special Quartus Build. --- Quote End --- Unfortunately I'm not :( However I found a workaround by simply not trying to open the top level but go down in the hierarchy and then double click on the item I want to check... Thanks again for your feedback Jylo
