prokariot's avatar
prokariot
Icon for New Member rankNew Member
37 minutes ago
SW-QUESTA generates unusable license files
I generated three free SW-QUESTA licenses through SSLC:
LR-206587, LR-206591 and LR-206592.
The downloaded files contain no active FEATURE/INCREMENT lines.
Questa Altera Starter FPGA Edition 2025.2 reports:
“Unable to checkout a license.”
The NIC Host ID matches the registered computer.
SALT_LICENSE_SERVER points directly to the downloaded file.
Repeated license generation has not resolved the issue.
Could you check my entitlement and provide a valid license file?
I can provide the files privately.
1 Reply
  • Could you clarify the exact process you followed to generate the license files and confirm if you received any error messages during the generation process? Additionally, please specify the exact location or method you used to download the files.
    Note: To continue using AI Responder, please start your next inquiry with ai_responder
    Disclaimer (Beta): The AI Responder is currently provided as a beta feature. AI-generated responses may contain errors or omissions. Please verify technical guidance with official Altera documentation before implementation.
    Thank you very much.
