10 years agoQuartus RTL Viewer crashes
I'm using Quartus II v13.1 for an existing project and wanted to check my design with RTL viewer after I made some modifications. Unfortunately, Quartus II systematically crashes with the followin...
10 years ago --- Quote Start --- If you're a big enough customer (ie, you buy enough chips) and the problem is going to block of lot of chip sales, you may get a special Quartus Build. --- Quote End --- Unfortunately I'm not :( However I found a workaround by simply not trying to open the top level but go down in the hierarchy and then double click on the item I want to check... Thanks again for your feedback Jylo
