10 years agoQuartus RTL Viewer crashes
I'm using Quartus II v13.1 for an existing project and wanted to check my design with RTL viewer after I made some modifications. Unfortunately, Quartus II systematically crashes with the followin...
10 years agoIf you're a big enough customer (ie, you buy enough chips) and the problem is going to block of lot of chip sales, you may get a special Quartus Build. But other than that, you're going to have to contact them
They may be able to tell you what the problem is anyway, and give you a work around..
