bpussacq's avatar
bpussacq
1 month ago
Quartus Pro 25.3 crash using rhel7/8
Hello everybody
I'm working on an Agilex-5 project since fex months on our internal couputer farm using Quartus Pro 25.3. To generate the final bitstream, a bash script is used to execute all the steps. Until now, we have no specific issue using this script with Quartus.
But since few days, we're unable to generate the project because Quartus Pro returns strange errors (see attachments). We also tried to use latest 23.5.1 version on an Ubuntu host under WSL and we also saw the same errors.
Running Quartus GUI may also end with same error. (see quartus_4.png)
Has anyone already experienced this issue?
Thanks a lot
Benjamin
  • Tom_CN's avatar
    Tom_CN
    We have also started seeing similar errors today. We have two PCs running Ubuntu 22.04.5 LTS (GNU/Linux 6.8.0-90-generic x86_64) and Quartus 24.1.
    It does not crash consistently each time. Below are some of the errors:
    Starting Quartus:
    $ /opt/tools/altera/intelFPGA_pro/24.1/quartus/bin/quartus &
    Error (22912): Unhandled exception:
    Fatal Error: Assertion failed tools/cpp/ddm/ddm_assessor.cpp:53: DDM_T::verify_token(token) : Cannot identify the client
     from function assertion_error in tools/cpp/ddm_report/ddm_report_msg.cpp@455
    *** Fatal Error: Program termination requested
    *** Below is the stack trace at the time the error occurred.
    *** The lines beginning "Err Handler" represent frames relating
    *** to generating this report.
    *** The point at which the error occurred is somewhere after these lines.
    *** There may be a few frames representing standard/library code
    *** before the Quartus frames begin.
    *** The search for the error should begin with the Quartus frames.
    *** Unwinder: libunwind
    *** Stack depth: 15
      Quartus          0x22142: err_terminator() + 0x1a4 (ccl_err)
      Quartus          0xa916a: __cxxabiv1::__terminate(void (*)()) + 0xa (stdc++)
      Quartus          0xa91d5: (stdc++)
      Quartus          0xa9428: (stdc++)
      Quartus          0x154eb: void ddm_throw<DDM_RUNTIME_ERROR>(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x3bb (ddm_report)
      Quartus          0x12cf9: DDM_REPORT::DDM_ASSERTION_HANDLER::assertion_error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) const + 0xc9 (ddm_report)
      Quartus          0x11918: DDM_REPORT::ASSERTION_HANDLER::error(std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >) + 0x68 (ddm_report)
      Quartus          0x12bd6: DDM_REPORT::detail::assert_at_line(char const*, char const*, int, char const*, ...) + 0x1b6 (ddm_report)
      Quartus         0x1ad479: ddm_set_lassessor(DDM_T_ASSESSOR*, std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> > const&) + 0x49 (ddm)
      Quartus          0xd2294: DMS_MANAGER::DMS_MANAGER() + 0x456 (dni_dms)
      Quartus          0xd23c4: DMS_MANAGER::get() + 0x7a (dni_dms)
      Quartus          0xd45be: _GLOBAL__sub_I_dms_manager.cpp + 0x7d (dni_dms)
      Quartus           0x647e: (ld-linux-x86-64)
      Quartus           0x6568: (ld-linux-x86-64)
      Quartus          0x202ca: (ld-linux-x86-64)
    During compilation:
    Error: UNAVAILABLE: Network closed for unknown reason
    Error: UNAVAILABLE: io exception
    Error: finishConnect(..) failed: Connection refused: localhost/127.0.0.1:35607
    Error: UNKNOWN: Application error processing RPC
    Error: Quartus Prime IP Generation Tool was unsuccessful. 132 errors, 22 warnings
    	Error: Peak virtual memory: 992 megabytes
    	Error: Processing ended: Mon Jan 12 17:55:06 2026
    	Error: Elapsed time: 00:00:52
    	Error: System process ID: 1339331
    Error(21794): Quartus Prime Full Compilation was unsuccessful. 134 errors, 22 warnings
    serv_req_info.txt:
    <?xml version="1.0" encoding="utf-8"?>
    <internal_error>
    	<sub_system>ERR</sub_system>
    	<callstack>*** Fatal Error: 	0x7f9e34172142: ccl_err + 0x22142 (_Z14err_terminatorv + 0x1a4)
    	0x7f9e2faa916a: stdc++ + 0xa916a (_ZN10__cxxabiv111__terminateEPFvvE + 0xa)
    	0x7f9e2faa91d5: stdc++ + 0xa91d5
    	0x7f9e2faa9428: stdc++ + 0xa9428
    	0x7f9e2f0924eb: ddm_report + 0x154eb (_Z9ddm_throwI17DDM_RUNTIME_ERROREvRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x3bb)
    	0x7f9e2f08fcf9: ddm_report + 0x12cf9 (_ZNK10DDM_REPORT21DDM_ASSERTION_HANDLER15assertion_errorENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0xc9)
    	0x7f9e2f08e918: ddm_report + 0x11918 (_ZN10DDM_REPORT17ASSERTION_HANDLER5errorENSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x68)
    	0x7f9e2f08fbd6: ddm_report + 0x12bd6 (_ZN10DDM_REPORT6detail14assert_at_lineEPKcS2_iS2_z + 0x1b6)
    	0x7f9e1edad479: ddm + 0x1ad479 (_Z17ddm_set_lassessorP14DDM_T_ASSESSORRKNSt7__cxx1112basic_stringIcSt11char_traitsIcESaIcEEE + 0x49)
    	0x7f9e30545294: dni_dms + 0xd2294 (_ZN11DMS_MANAGERC1Ev + 0x456)
    	0x7f9e305453c4: dni_dms + 0xd23c4 (_ZN11DMS_MANAGER3getEv + 0x7a)
    	0x7f9e305475be: dni_dms + 0xd45be (_GLOBAL__sub_I_dms_manager.cpp + 0x7d)
    	0x7f9e35c9147e: ld-linux-x86-64 + 0x647e
    	0x7f9e35c91568: ld-linux-x86-64 + 0x6568
    	0x7f9e35cab2ca: ld-linux-x86-64 + 0x202ca
    </callstack>
    	<error>Program termination requested</error>
    	<date>Mon Jan 12 17:54:02 2026
    </date>
    	<version>Version 24.1.0 Build 115 03/21/2024 SC Pro Edition</version>
    </internal_error>
  • bpussacq's avatar
    bpussacq
    I forgot to mention that we're using LSF8 for dispatching jobs on the computer farm.
    • ShengN_altera's avatar
      ShengN_altera
      Internal message as below:
      There was a Quartus Prime Pro issue broadly discovered by customers, field and internal teams in which the Quartus code that calculates the date and time from the DDM client ID mistakenly identifies the time being shifted an hour from the current time which in turn, causes a Quartus crash to take place.  This issue began when the year turned to 2026 and we moved to a two-digit date in the month of January.  This crash affects:
      Quartus Prime Pro Software versions v23.3 through v25.3.1
      Quartus Embedded Edition v25.3 and v25.3.1
      Quartus Programmer v23.3 through v25.3.1
      This issue can be seen when using Quartus software through command line or GUI interface.
      Quartus Patch requests have been filed for the above software and tools.  A KDB draft is available and will be reviewed and released when the patches are ready.  These fixes and KDB are being driven with utmost priority.
      Will get back once the patch and kdb are available.
      • SteffenP's avatar
        SteffenP
        Can you confirm that patches for Quartus Prime Pro v25.3.0.109 will be available ? It's the latest version with Stratix10, Arria10 and Cyclone10 device support (v25.3.1.100 only support AgileX variants).
        Cheers,
        Steffen
