PTrig
1 year agoQuartus Pro 23.4 installer unable to unzip agilex common QDZ file error
I am facing an install issue, where the installer is unable to unzip agilex-common qdz file. I have tried multiple ways and it is consistent every time. I don't have issue in other files, other com...
PTrig
1 year agoHi,
Thanks for your responses !
Did try all the methods suggested above. I believe the option for --unzip_tool should be used only for the top level installer/launcher.
I solved the issue, by using the tar files. They throw the same error, but if we invoke QuartusProProgrammerSetup-24.3.1.102-windows with the --unzip_tool, then it worked.
I have license issue now, the free license is not being picked up, and the old 18.1 license file works. I will continue debug on that.
Thanks again to both of you, for your responses
We can close this now.
Pranav
