PTrig
1 year agoQuartus Pro 23.4 installer unable to unzip agilex common QDZ file error
I am facing an install issue, where the installer is unable to unzip agilex-common qdz file. I have tried multiple ways and it is consistent every time. I don't have issue in other files, other com...
sstrell
1 year agoAre you using the newer complete small installer that downloads files as needed or some other method? Maybe list exactly what steps you are following to get to this point because it is not clear, especially since you reference a post about Linux but you are clearly using Windows.
.qdz is not a compressed file per se. I always download from the "individual files" tab at the download center all the files I need.
