ATseo
6 years agoQuartus Prime Standard 19.1 silent installation with SCCM
We deploy software at our university using SCCM. Deploying Quartus Prime Standard 19.1 as an available (user initiated) install works fine when using silent switches. When deploying as a required (no...
ATseo
6 years agoThis command line works fine when installing manually or using Group Policy. It does NOT work when using SCCM. Did you test this with SCCM?
RichardT_altera
6 years agoHi, could you try to run the installer with: --skip_registration 1
this will skip installing some prerequisites, adding some registry entries.
Try to see if the installation can succeed.
If not, try running it with: --syncdebugtrace debug.txt
then pass us the debug.txt file. I'll ask the vendor to examine it.
