Quartus Prime Standard 19.1 silent installation with SCCM
I did not saw this behavior in my own machine and I am able to open quartus after installation.
OS Platform: Window 10
Quartus: 19.1 Standard version
The command line that I used is the same as the one that you used. Perhaps you can check whether the System Requirements and Prerequisites are met during installation. Or run the command prompt as administrator.
System Requirements and Prerequisites: https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/manual/quartus_install.pdf#page=5
- ATseo6 years ago
This command line works fine when installing manually or using Group Policy. It does NOT work when using SCCM. Did you test this with SCCM?
- RichardT_altera6 years ago
Hi, could you try to run the installer with: --skip_registration 1
this will skip installing some prerequisites, adding some registry entries.
Try to see if the installation can succeed.If not, try running it with: --syncdebugtrace debug.txt
then pass us the debug.txt file. I'll ask the vendor to examine it.- ATseo6 years ago
I missed your last reply. Will test the first option and if it fails, will provide debug log.
