Quartus Prime Pro 25.1 Crashes Randomly
Can you attached the design? Also, what device that you were using? Can you use the latest release of the Quartus Std? If no, any reason?
Hello, the FPGA I’m using is no longer supported (I assume) in the newer versions of Quartus—it’s an older Cyclone III. The design itself isn’t problematic, since it’s the same one I’ve been compiling for a long time, with only minor changes in each build. Moreover, the error occurs when opening the program, it doesn’t even need to reach the compilation stage. In any case, it seems that reinstalling the software and the previous system reformat have solved the issue.
- KennyT_altera7 months ago
Is there further question?
- ingemilo7 months ago
The problem apparently solved just by reinstaling the software newly, thanks for the help.
Good to hear that, we shall close the case.
