Quartus Prime Pro 25.1 Crashes Randomly
Hello cblixt, thank you for your response. I’ve tried installing the patch, and it seems to have solved the issue—at least the two compilations I ran after installing it completed successfully, and no text file was generated. However, I don’t understand the origin of the problem or how it’s possible that it also affects such an old version of Quartus as 13.1, which I use for some older FPGAs. When I try to compile a project for those, a similar error appears, and the program closes.
- cblixt8 months ago
This is not the same problem. That problem affected only Quartus Prime Pro versions 23.3 - 25.3.1, that's why there are only patches available for those versions.
If you have another problem happening in Quartus 13.1 I don't expect that to have suddenly appeared on Jan 10 like the above mentioned problem did, and I would recommend posting a new question for it with an adjusted title.
- KennyT_altera7 months ago
Can you attached the design? Also, what device that you were using? Can you use the latest release of the Quartus Std? If no, any reason?
- ingemilo7 months ago
Hello, the FPGA I’m using is no longer supported (I assume) in the newer versions of Quartus—it’s an older Cyclone III. The design itself isn’t problematic, since it’s the same one I’ve been compiling for a long time, with only minor changes in each build. Moreover, the error occurs when opening the program, it doesn’t even need to reach the compilation stage. In any case, it seems that reinstalling the software and the previous system reformat have solved the issue.
Is there further question?
