Quartus Prime Pro 25.1.0 Reports Unconstrained Paths in Cyclone 10GX PCIe Hard IP
Check the .sdc files being included in the project in the Timing Analyzer settings. Maybe it's using the old .sdc files instead of new ones generated when the IP was regenerated.
I have already checked the .sdc files being included in the project in the Timing Analyzer settings and no issues are found. I also removed the IP from the project, deleted the generated IP folder within the project directory and then generated the IP from scratch. The errors are still there.
I suspect there might be errors in the generated .sdc files. The compilation flow shows a green tick before the Timing Analyzer. This indicates the design has passed the Timing Analyzer. I will compare the new sdc file with the old one and see if I can find anything.
- sstrell1 year ago
No the green checkmark doesn't mean that the TA met all timing. It just means the TA completed its run.
