liyihang's avatar
liyihang
9 months ago
Quartus Prime Pro 24.2
当我用Quartus Prime Pro 24.2编译IP核心时,遇到过类似问题。有老师能帮帮我吗?
  • KennyT_altera's avatar
    KennyT_altera
    This problem require you to attached the design.qar for us to investigate. Can you provide us?
    Also, is that possible that you use our latest release of Quartus Prime Pro 25.3? If no, what would be the reason?
  • wangduoyu's avatar
    wangduoyu
    之前公司装加密软件的时候,部分进程会被加密,从而导致编译过程中文件和进程无法被识别、报一样的错误。不知道你是否也是在加密环境下调试,如果是的话可以考虑将所有相关进程加入白名单
    KennyT_altera
    in that case, may I know what software that you have install? Also, can you attached your design.qar for us?
    KennyT_altera
    Is there any update for the above request? If no, we shall close this case.
