DerekNH
2 years agoQuartus Prime Pro 23.4 internal error during fit when module marked as a partition
I am working to package my portion of a Stratix 10 design so that it can be used as a "finalized" partition within a larger FPGA implementation. However, when I mark my top level module as a partitio...
- 2 years ago
If you have Quartus Pro version 23.2 or earlier handy, I'd be curious to know if the issue also appears there or not.
Versions 23.3 and 23.4 use "DNI", a new internal database framework, which introduced other new bugs related to partition functionality. See:
SyafieqS
2 years agoUnderstood. Is 23.2 earlier is feasible for current development?
I would suggest to use to as workaround.
It is hard if there no design to replicate to root cause the issue and would be better if you are able to provide.
- DerekNH2 years ago
Is there a flow by which we can provide a testcase privately and under NDA? I have been unable to simplify the test case in a way which reproduces the error and does not have proprietary code.
Otherwise, yes, we will use 23.2 as a workaround.
Thanks so much,
Derek
