1 Reply
- sstrell
Your setup in Quartus doesn't really matter for your issue since you're using the Lite edition.
As for QuestaSim, it looks like you have the environment variable set up correctly. Is this a newly generated license file? Open up the .dat file and check the date and that the MAC address is correct for a network interface on your computer.
You should also run lmutil lmdiag as suggested.
